It's always best to start with the correct template.
Imperial for inches and feet
Metric for millimeters (or whatever metric unit you need to use)
If you have a metric drawing that used millimeters, copy and past into an imperial (inches and feet template)
and scale the geometry up x 25.4
You can cross check MM to Inches and MM to Feet here.
