How do you set default measure to properties for windows and doors?
mikeshick
mikeshick
Thank you,
Mike Shick
www.medesigns.us
pendean
Community Legend
Community Legend
default measure? Please elaborate, what are you expectations for example vs what you get in an all new project file started from scratch from a core ACA template.
mikeshick
I think I found the answer.  I needed to change the "Measure To" property of windows on the Tool Palette so when inserting onto a wall, the outside of frame would default instead of inside of frame.
Thanks for responding.
Have a great day.
Mike Shick
www.medesigns.us
David_W_Koch
Yes, changing it on the Properties palette should make it the new default until the next time you change it. The same holds true for Doors.
If you use Tool Palette tools to place Windows or Doors, you can also specify a value for the Measure to property in the tool's properties.  Using a Tool Palette tool with a specific setting will not reset the default value, but will apply it to objects placed by the tool.  This is handy if you typically want to measure to outside or inside of frame for nearly all objects, but have a few styles where you want the non-typical value.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
mikeshick
Thank you, David.  I appreciate the feedback!
We made a recent change to our structural framing plans, and it had been 20ish years since I had set it up previously.  I couldn't find the settings for a bit.
Thanks for your help.
Mike Shick
www.medesigns.us
