How do you deal with Multiple Materials on the same wall
Hey Everyone,
I've been playing around with walls a lot lately, and was trying to figure out how I would go about creating a wall that essentially has two materials on it (or Textures/Hatches).  For example.  Let's say you have a wall that's 10 ft high, and you want the first 6 ft to be Brick, and the last 4ft to be siding.  Would that be two walls, one 6ft high, and the other 4ft, or one wall with two textures?  Having trouble wrapping my head around this one.  Thanks!
KPM
dbroad
Open your design tool catalog, load a few of the wall styles and use the wallstyleedit command, and look at the components tab. At the far right, note the bottom and top elevation offsets.
Note: When you change a wall by adding a component, this will affect your endcaps and opening endcaps and you will need to create a new definition. With components in the same layer that might be different thicknesses, the shrinkwrap will be controlled by the cut plane.
Architect, Registered NC, VA, SC, & GA.
Victoria.Studley
Hi @kevinpmcauliffe,
Here's a quick Screencast to show you the workflow you might use to create the kind of multi-component wall you're describing:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestions that @dbroad or I provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
