help with AEC elements
Hi Everyone
Please Help,my project have an Aec Railing, the railing is round. How can I smooth the curves of an AEC element. Is Not a Solid, is a AEC Element
David_W_Koch
AEC Objects will represent curves with facets.  You can increase the number of facets used, to make the object appear smoother.
FACETDEV
http://docs.autodesk.com/ARCHDESK/2013/ENU/filesARCHDESK/GUID-91443EBD-2E12-44F2-9D87-89573008CC87.h...
The minimum number of facets for a full circle is 8.
FACETMAX
This sets the maximum number of facets for any one curve.  It can be used to enhance performance where you have a wide range of curve radii, allowing you to set a lower value for FACETDEV so that small radius objects look smoother while minimizing the performance hit on large radius objects.  You can set FACETMAX to a value from 100 to 10,000, inclusive.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
thank you !! i undertand the command
but the problem in my project continues
i try facetdev, facetmax and aecfacetdev but nothing
in my aec element like wall o railing, no curves are increased
what am I doing wrong?
David_W_Koch
Some items, like Mass Elements in one of the standard shapes, like Cylinder, will react to changes in in the value of FacetDev.  Others, like Freeform Mass Elements, have their facets set based on the values for FACETDEV and FACETMAX at the time of creation, and will not adjust to subsequent changes.  You will have to recreate the latter objects with the revised FACETDEV and FACETMAX values active.
David Koch
Blog | LinkedIn
dbroad
To add to what David said, there will always be facets.  These objects will never be truly curved. The faceted geometry is programmed in.  The only thing you can do is make them appear smoother when needed or coarser to speed editing.
Architect, Registered NC, VA, SC, & GA.
thanks!!!!!!
my problem is solved
