HELP! HOW WILL I MODEL THIS IN AUTOCAD ARCHITECTURE
Message 1 of 8
Below is the work-in-progress floor plan of the rendered image. the rendered image was done using other software. i want to be able to do same on Autocad architecture. how will i do this? how will i be able to use body modifier/ mass element to achieve all those extrusion done on the wall before i render it?
Answers needed urgently please
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
So your image was done in Photoshop according to the file's embedded details: so it's basically a colored-in static image. Nothing more, it's not a 3D model, has no lighting, it's not a rendering nor was it created with anything like what is available in AutoCAD ARCH.
So it that all you want to do, color in a static picture? Photoshop is a good tool for that, there are cheaper offerings out there that do the same.
AutoCAD ARCH is not a photo coloring program.
Message 3 of 8
thank you. this is another rendered work. how can i achieve this same thing using autocad architecture using body modifier/mass element/3d solids.
Message 4 of 8
pendean
Community Legend
Community Legend
HELP can get you started, free videos on YouTube and free blogs with Tutorials you can find using Google Search will get you further along.
I'll get you started:
https://www.augi.com/articles/detail/autocad-architecture-rendering-basics
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
https://www.youtube.com/watch?v=k7AGiTE4SK0
There is no shortcut: you have quite the learning curve ahead of you.
Message 5 of 8
ntellery
There are various ways to do different corbels and piers and often you can use different ways for the same outcome.
Your image "postrender" looks to have a consistent corbel running around the whole building horizontally.
You could add a componant to your wall style and have it stick out a bit and stop your main componant at the bottom of the corbel and another wall componant above the corbel.  Having the top bit as a separate componant allows you to apply a different material (colour).
For quick solutions if you are stuggling to learn you could just add either a masselement or structural element around the wall at the required height and maybe another above to cover the main white wall componant.
Not sure what the bottom black is.  Perhaps just a masselement with the shape applied.
For the window reveal corbels I would use an aecWindowAssembly or aecCurtainWall with all elements except the outside frame turned off and apply if necessary a profile (insitu) to get the shape.  I just place the surround manually and stretch it into position. It's not intelligently attached in any way.
For "design 1"pretty much the same things for the corbel and window surrounds.
Often if I just need to get something done quickly I would just create a 2nd wall and place it at the correct height etc so for the front white piers you might just add another wall in front (which is what it is anyway).
The planters at the front could be one wall style with 3 componants.
Your eave coving could be another wall style with a profile applied to the appropriate componant or because it's all the one colour you could make the whole thing out of one componant and apply a profile to the whole thing at once.
I tried to share some tips with my solutions on my blog years ago so perhaps they might be helpful.
ausaca.blogspot.com.au search label wall styles
ausaca.blogspot.com.au search label body modifier
Be aware there is a lot to learn to complete what are really simple tasks but once you have these skills you will find them very handy.
If you can find the Autodesks Virtual University they do have some great indepth videos on walls etc.
Edit:  I've attached a quick mockup of a corbel line using another componant and a window surround.
Your walls are not consistent so it does not align around the corner.  Just flip your arrow on the wall so they are both set the same way and they mitre fine.
You should be using custom walls, not just standard wall otherwise all your walls will be the same so I turned your external wall into it's own style.
Sorry but you have a lot to learn 🙂  Good luck.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
Message 6 of 8
gotphish001
You're asking kind of a complex question. It's almost impossible to answer. It's like posting a picture of a corvette on a mechanic forum and asking "How do I build this in my garage."
Nick DiPietro
Cad Manager/Monkey
Message 7 of 8
thank you very much. i have tried as much as possible to find a training centre in my country here, but i couldnt get one that offers autocad architecture but i got Paul Aubin tutorial on autocad architecture from lynda. he only discussed about using the software for construction drawing mostly. please, do you know of any other video tutorial that i can get that explain mass element/3D solids through rendering.
Message 8 of 8
thank you. this helps. will check out those video tutorials . your blog has always been helpful
