AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Hatches are recognized as multiple objects
2 REPLIES 2
impressif
287 Views, 2 Replies
Hi Autodesk Community,
I have a problem with my hatches in AutoCAD Architecture: Hatches are recognized as multiple objects, therefore it doesn't open the hatch edit Menu on top (in German "Schraffureditor"), I always have to use the HATCHEDIT command to change anything (German SCHRAFFEDIT).
I also can't use "ADDSELECTED" because then it tells me that you can't use the command when selecting multiple objects.
I played around with some settings in the HATCHEDIT but nothing seems to work...
______________
Update:
I have found a workaround with the Settings from the "Screenshot workaround so far" - by creating the Hatch and then removing the Polyline that it created, then leaving me with only the Hatch left and the hatch is recognized as hatch again. So for every hatch I create I still always have to remove the polyline.
If I create the hatch without polyline in the first place, the borders of the hatch follow the surrounding lines and are very weird, so I need to have a polyline created for "good" borders.
Fast help would be great, as I have an exam tomorrow and the day after... and using HATCHEDIT is a little slower...
Thank you so much for helping!
Sorry for my English and greetings from Germany!
2 REPLIES 2
David_W_Koch
in reply to: impressif
@impressif
Welcome to the community!
If you are creating associative hatches (hatches that remain associated with the boundary object(s) and update when the boundary object(s) are changed), then you should check the setting of the PICKSTYLE system variable.
This controls how groups and/or associative hatches act when selected.  If PICKSTYLE is set to:
  • 0, selecting a member of a group or an associative hatch only selects the selected item.
  • 1, selecting a member of a group selects all members of the group.
  • 2, selecting an associative hatch selects the boundary object(s) as well.
  • 3, selecting an associative hatch selects the boundary object(s), and selecting a member of a group selects all members of the group.
From your description, it sounds like you are using associative hatches and PICKSTYLE is set to 2 or 3.  Set it to 0 (or 1, if you want to select all members of a group when selecting one) to only select the hatch while still keeping the boundary object(s).
If you prefer dialog boxes to command-line typing, you can control the setting of PICKSTYLE through two toggles in the Options dialog, on the Selection tab, in the Selection modes area:  Object grouping and Associative Hatch.  Check the toggle(s) to activate group and/or associative hatch/boundary selection; clear the check marks from the toggle(s) to deactivate that(those) feature(s).
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
impressif
Hello David,
thank you so much for helping me and for putting in time and effort to solve my problem! It was exactly that.
It was set to 3.
I had spent hours on trying to fix the issue and would've never guessed that.
Thanks so much again! 🙂
Greetings
Technology Administrators
