Grid Layout
Grid Layout
cadwork12
Message 1 of 19
Grid Layout
cadwork12
I'm doing a lesson on column grids; in layout mode you can choose manual, repeat, or evenly spaced.
I'm stuck on repeat if anyone knows what I'm talking about.  If you select it you get
1.  Enter start offset on x-axis
2.  Enter end offset on x-axis.
3.  Enter spacing on x-axis.
Can someone describe what these directions mean for the repeat command?
Thanks.
Replies (18)
Message 2 of 19
R_Tweed
The below layout has a start and end offset of 12" and a repeat of 26' for grids 1-4.  You will see this commonly used with prefabricated metal buildings.
Message 3 of 19
cadwork12
I see what the offsets are, I entered values, but they are not visible, is there an option for this?
Message 4 of 19
R_Tweed
Sorry, not that I know of. I use offsets when I know the size of the space and want an easy way to control the first and last column lines.  If you want to see a grid line then I don't see a need to use the end offset. You can achieve this by adding another grid line and not labeling the end grid lines.
Message 5 of 19
cadwork12
Last question, "space evenly"...
It only asked for start offset and end offset but does not ask for anything else?
Message 6 of 19
R_Tweed
I use the properties palette to enter information during layout and later to make modifications.  The space evenly, manual and Repeat options are a pulldown and the spacing will either be informational or editable depending on your selection.
Message 7 of 19
cadwork12
Great thank you!
Message 8 of 19
cadwork12
What is the purpose of an overhang on a slab?
Message 9 of 19
R_Tweed
The short answer would be edge treatment.  Overhangs and edge style can be adjusted or added for several edges in one action which can be useful.  See below for an example.
Message 10 of 19
cadwork12
Thanks!
Message 11 of 19
cadwork12
Much appreciated and sorry to bother, edge treatment is for the sake of appearance or structure?
Message 12 of 19
cadwork12
Message 13 of 19
R_Tweed
I would say both.  It depends on what you want from the model in terms of data and your preferences for section and elevation presentation.  Information regarding soffit and fascia profiles etc. can be accessed through the use of property set definitions if you are looking to build scheduling or estimates.
Other methods to create the edge treatment below would be to create another two slabs and maybe add a curb using a wall.
Message 14 of 19
cadwork12
Your help is really appreciated, I'm trying to teach myself AutoCAD ARCHITECTURAL. A few simple questions.
When I open a drawing the grid size is a bit large 100' to the length of a square. How can I adjust this.
Message 15 of 19
cadwork12
Also the tool palette has disappeared, the palette with walls/slabs, doors, etc. How can I recover this?
Message 16 of 19
David_W_Koch
For the Grid issue:
Right-click on the Grid tool on the Status Bar, and choose Grid Settings (only choice).  [Alternate:  Type DSETTINGS at the command line and press the ENTER key.  Select the Snap and Grid tab if it is not already current.]
Enter the desired values in the Grid spacing area.  Do this in your template file(s) if you want all new drawings to start with these settings.
CTRL+3 will toggle the visibility of the Tool Palettes, assuming that is what is not visible, and that they are just turned off, and were not moved to a position that is off-screen.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 17 of 19
cadwork12
I'm trying to create a dormer, gotten this far, trying to select the dormer parts, I've attached a snip and an AutoCAD file.
Thanks for any help you can offer!
Message 18 of 19
R_Tweed
I believe this blog is what you are looking for,  http://ausaca.blogspot.com/p/roof-object-video-links.html  by @ntellery to run through roof basics to dormers.
Message 19 of 19
R_Tweed
Feel free to post or create different threads for each subject (roof, grid, walls etc.) . It will make it easier to find when replying based on subject.
