Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi, I am begginer in autocad. I have downloaded autocad 2013 in my macbook pro yosemite recently and trying to learn basics. The problem is when I tried to use fillet and chamfer, both are not working properly. I am trying to use them exactly the same way how others are using. I selected fillet and then typed 'r' and hit enter. Then I put radious 2.5 and hit enter. Then I selected first line and then second line, but nothing happened.
Please tell me what to do, I hope you will have a salution. I have searched everywhere already.
I found it just now that if I open my new drawing in acad templete, I can draw it as I was trying.
But now I want to delete this post from this forum, I couldnot find it, Can someone tell me?
Hi @Anonymous,
Thank you for posting your question. There's no need to delete the post once you've found a solution. I'll go ahead and mark your second post as the solution for this thread, as it could help others who encounter the same issue.
In the future, if you're using AutoCAD for Mac, there is a dedicated forum for that specific software (this forum is for AutoCAD Architecture, which is an AutoCAD vertical program for Windows systems).
You may find some additional tips, tricks, and resources to help you get started over in the AutoCAD for Mac forum - I recommend checking it out!
