Hi
I'm using AutoCAD Architecture 2008 SP1 on a suite of 3 PCS.
I'm getting the above error when opening 1 file on the 3 PCs.
The file in question can be opened using AutoCAD 2007.
I have tried saving the file using a different formats, makes no difference....
I have reinstalled Architecture & SP1 & last night I done a chkdsk /r on 1of the 3 machines to see if that made any difference. No.
I have searched the discussion groups, I see a few have had the problem but when performing different functions within the software, I'm getting the error when opening a file.
Any ideas?
Solved by HueyMcGovern5328. Go to Solution.
Solved by pendean. Go to Solution.
RECOVER command to open the file fix it?
AUDIT command while you are in it?
WBLOCK the contents of the file to create a new one, then INSERT this new file into a working trouble-free template?
There are so many ways to fix a file before the drastic option of reinstalling AutoCAD (which normally will not fix a problem file).
