Exporting to PDF causing faded lines
Good afternoon,
When i export a drawing or a DWF to PDF; certain annotations and lines become faded as if the ink was low.
If i print directly from AutoCad with monochrome plot style table selected, the drawing comes out perfect.
The red is what looks faded and the blue is what it should look like.
Suggestions?
pendean
Community Legend
Community Legend
Post the actual PDF: I suspect its your PDF Viewer's settings and nothing else.
If you cannot share your PDF, zoom into the faded lines, if they suddenly look fine the closer you get to them you need to adjust the display settings in your Acrobat Reader.
Victoria.Studley
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Will you be able to post the PDF file and information that @pendean requested in order to continue helping you?
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
