AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Export Pallet
2 REPLIES 2
kalebBBJUX
247 Views, 2 Replies
Export Pallet
I’ve seen screen shots of people who have the ability to “export tool palettes”.
when I try do the the same, the export tool feature is missing.
how can I re enable this so I can share my palette with my team?
2 REPLIES 2
dbroad
in reply to: kalebBBJUX
AutoCAD tool palettes can be exported but ACA content must be shared differently.  Use the contentbrowser to build catalogs, categories, packages, and tool palettes that can be shared by "publishing".  You can also use the generate tool catalog ribbon command on the customization panel of the manage tab.
Architect, Registered NC, VA, SC, & GA.
handjonathan
Hi @kalebBBJUX
Thanks a lot for posting your question to the forums!   Has the solution suggested by @dbroad  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Forma Design Contest
