execute new model space view... from command line
jcpLPAKD
jcpLPAKD
Does anyone know how to call the add Model Space View dialog from the command line?  Currently you need to right-click the drawing on the view tab of the project navigator and select the New Model Space View.. from the list.
I know that you can also create views using the View Manager but it actually has more steps because of all the confirmations required.
Thanks in advance.
rwrightWMDSY
Command is MVIEW.  To set scale:  with model space active enter ZOOM then 1/48XP for 1/4" = 1'-0" scale.
jcpLPAKD
MVIEW is used to create a paper space view.  I am looking for a way to create named model space views, in the fewest possible steps, in a view drawing that will show up in the view tab of the Project Navigator and can then be dragged into sheet drawings.
I am creating 20 or more large scale connection details, that are not being pulled from a model, so the views are not automatically being created.  The Add Model Space View dialog is very efficient a creating new views but you cannot hit enter after creating a view to restart the dialog.  You need to go back to the Project Navigator and start the process all over again.
