@legrand_design wrote:
Yes, I remember that I migrated an earlier user interface when I installed AutoCAD Architecture 2016.
OK, these expanded nodes are identical to your image.
The main customization file I am working with, ACA.CUIX, is not the out-of-box file however. Is this going to be an issue ?
I probably can't check in again until after the holidays.
It should not be an issue. With an emphasis on the "should", since there is apparently some issue. Time will tell on that front.
The next thing to check is what panels are assigned to the tabs that are assigned to contextual tab states. Expand the Tabs node under the Ribbon node and look for the tabs that were listed for the contextual tab state(s) of interest. Expand those to see what panels are assigned.
Are the panels assigned the same as in my image?
If so, I was going to suggest expanding the Panels node, and looking for the Panels, to make sure that the definitions exist, and have the proper tools assigned, but I found that the "IPE" panels shown above are not shown under the Panels node. Perhaps they are hidden, so that end users cannot mess with them and possibly cause problems with the contextual ribbon tab functionality. I will see if I can dig something up on this.
Picking this up again after the holiday break works for me. I will be around; I am not going to AU this year.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
