DWG to KMZ file
DWG to KMZ file
Message 1 of 9
DWG to KMZ file
Hi Guys,
I am trying to convert a DWG file to KMZ so I can view it in Google earth. I have the 2012 auto cad version for students and do not have a plugin to do this. Do you know if there is a simple way to convert this DWG file?
Replies (8)
Message 3 of 9
John.W.Mumaw
The pro version of Sketchup will convert drawing files to kmz.  You can get a trial copy and check it out yourself.
John
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
Message 4 of 9
THANKS! I will try this out!
Message 5 of 9
Thanks for the suggestion!
Message 6 of 9
Any program to convert from .KMZ to .DWG and viceversa that runs in MAC?
Message 7 of 9
damacylo
Try with
https://mygeodata.cloud/converter/autocad-to-kmz
Daniel Avila
Hydraulic Eng.
Message 8 of 9
damacylo
Or try
https://www.gisconvert.com/#
Daniel Avila
Hydraulic Eng.
Message 9 of 9
damacylo
