(I was sent here by a chat agent at AutoDesk.)
I'm still using Architectural Desktop 2006 and have problems with Windows 10. I actually need to reinstall it and can not find the install files anywhere. Could anyone help provide med with a download so that I can install the software again?
Thanks!
I don't believe ACA 2006 was installable via download but versions are only supported for 5 years maximum in any case. The download link probably no longer exists. If it does, you will find it if you log into your account on Autodesk.com.
You should have the installation package on your computer though. ACA 2006 is not officially supported on Windows 10. Suggest you upgrade or contact your vendor.
Thanks for replying.
I have got confirmation the link/download does noe exist, officially.
I've had the software working on Windows 10 for a long time, but will get Windows 7 if I am able to get a copy of the software.
Chat-support told me that I might be so lucky as to someone in the forum here have a download link for me. Of their own copy. They actually told me to ask if anyone else could supply it, hence I am assuming they see it as legal for med to download from an unauthorized source.
Still hoping someone could help me! Shared by any means you see fit.
Sounds reasonable. Good luck. Be sure however that yours is unavailable. The installer generally gets saved to a default location under the C:\Autodesk folder unless you changed that folder. Back then, I think, Autodesk was sending out either DVD's or thumb drives (can't remember which).
I have no information on the veracity or safety of this link. But this is what I found. You'll still need your original Serial # and Auth code.
http://autodesk-architectural-desktop.software.informer.com/2006/
Allen Jessup
CAD Manager - Designer
