In AutoCAD Architecture 2015, using the AEC dimension command, and making the dimension associated to an object, some the extension lines randomly extend themselves ( either across the drawing, or away from the drawing ) every time the drawing is opened, even if they are corrected and immediately saved. Is there a way to prevent this?
Solved by Victoria.Studley. Go to Solution.
Hi floorplanz,
Can you share an affected file with us? So we can test it in our environments for testing purposes?
Unfortunately, there's no attached files in your post, Bryan. Can you try it again?
Hi @Anonymous,
Thank you for posting your question here in the community. I've analyzed your file and it looks the issue is being cause by some file corruption.
I was able to resolve the error as follows:
Hi @Anonymous,
I'm checking in again today to see how you're doing with this. Did my recommendation for repairing the file yesterday work for you?
