Hello All,
I have a pesky file that I just can't seem to region. I did a pedit multiple to close it and it still won't region. I deal with a lot of vendors line so maybe this is the issue.
Can anyone take a look see and check if you can region it. I have been pulling out hair for a couple hours. I have had this issue, along with bpoly and pedit over the years which has been frustrating. I tried Wblock and Flatten as well....yoy. I can usually get things closed and regioned eventually but this one is nuts.
If it matters, I am using ACA 2014 on a Dell Precision T7500 Win7, Quaddro FX 4800
Knowing why it happens and how to fix it will make me happy....
Any and all help appreciated.
Tom
Solved by dbroad. Go to Solution.
Explode, overkill (just to be safe), delete the indicated arc and use fillet to recreate it. Then use mpedit, select all, and join them with 0 fuzz.
Thanks Prof D,
That worked great. As you can see there are tons of entities so what clued you in to that one radius?
Inquiring minds need to know....lol
Thank you fine sir.
Tom
Excellent info DBROAD I went around the perimeter but wasn't zoomed in enough to see it. It only measured 0.00001933.
No wonder I have had these issues over the years. I need binoculars.
Thanks again
Tom
