I have problems with demand loading in AutoCAD Architecture 2017, when i try to load the .DLL file by adding path in Registry Key, it gives error as Unknown Command.
How to somehow load DLL on startup?
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R21.0\ACAD-0007:409\Applications\CSharpDLL]
"DESCRIPTION"="CSharpDLL"
"LOADER"="C:\\Program Files\\CSharpDLL\\Test.dll"
"MANAGED"=dword:00000001
"LOADCTRLS"=dword:00000002
Omkar Gavand
Solved by Keith.Brown. Go to Solution.
When you demand load, your LOADCTRLS should be equal to 12. You also need to define the commands in a subkey.
Please see this article http://through-the-interface.typepad.com/through_the_interface/2006/09/automatic_loadi.html
And pay attention to the instructions under the Loading Modules on command invocation section.
