Deleting all objects without selection
dmitriZTSCC
Message 1 of 9
dmitriZTSCC
I need to delete every single object in my model in one command. Unfortunately, the typical approach of ERASE → ALL → <enter> does not work well because the ALL part makes a selection of every single object. Since I have thousands of objects in a generated model, this causes AutoCad to lock up for several minutes (!!!).
So, my question: is it possible to somehow clear the entire model without selecting anything? I know I can close the file and open a new file, but this is somewhat annoying.
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
No.
Why, if I may ask, is this not more than a one-off need that would not take but a 2-minutes to implement manually? What is the purpose you are striving for here, perhaps a different workflow exists to better meet your need.
Message 3 of 9
dmitriZTSCC
I am generating masonry layouts for a house I've just built. The masonry layout is composed of thousands of individual bricks that cannot be homogenized (i.e., the use of textures is not possible). This results in a model with floors and windows and thousands of individual bricks (each is a BOX). Selection of all these boxes is where an epic slow-down happens.
Message 4 of 9
pendean
Community Legend
Community Legend
>>>...Selection of all these boxes is where an epic slow-down happens....<<<
That's probably not going to be any faster with all other objects erased: you can test it yourself, simply FREEZE all the layers of all the other objects (assuming your bricks are on a unique layer). Same effect as erasing everything else.
Are these individual bricks actual BLOCK object types too? Or something unique like a solid (you wrote BOX) on a dedicated layer?
Message 5 of 9
dmitriZTSCC
No, these objects (created with the BOX command) are neither part of a BLOCK nor part of any separate layers.
Message 6 of 9
pendean
Community Legend
Community Legend
SELECTSIMILAR or QSELECT or FILTER commands should pick them alone if nothing else, then WBLOCK to create a new file with only these "bricks" in the new file. (and if you wish, a good time to isolate them into a unique layer).
You will face the same problem, slowness exists until you get past it I am afraid, your having that many quantities of free individual items that where not combined into blocks (per wall, or per feature or...).
Good luck.
Message 7 of 9
dbroad
What is the advantage of destroying the data in a file vs starting a new file?  I don't get it.  If everything goes, delete the file.
Architect, Registered NC, VA, SC, & GA.
Message 8 of 9
dmitriZTSCC
The advantage is I get to keep the layer definitions, viewport settings and preview settings, among other things. I don't want to have to keep re-doing them all the time.
Message 9 of 9
dbroad
That is generally what templates are for.  AutoCAD Architecture automatically creates the layers you need on the fly however so I usually use the default templates for layer settings.  Project templates are a good approach if you want to save sheet layouts.
To create a custom template, try this. Put up with the deletion delay.  After deleting the objects in each drawing category you want a template for, save those drawings as templates.  Then begin using those templates for new projects.
