Deleted tag attribute inside a block still appear
maurotrotta
maurotrotta
I did an tag attribute that I placed inside a block. Now I realize that I don´t really need this tag and could simply an mtext instead. So I went and edit the block, erase there the Tag and save changes, but the tag attribute is still there. How can I get rid of it? I already purge the drawing and nothing about the tag appear.
David_W_Koch
Newly placed instances of your block will be attribute-free, but any that were placed before you deleted the Attribute Definition from the Block Definition will remain.  You can force the pre-existing blocks to conform to the modified Block Definition by running the ATTSYNC command.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
