Yes, that's my opinion. Perhaps I should clarify:
Per National CAD Standards, there should only be one plotted layout per sheet file. I often ignore that in AutoCAD, especially when not using sheetsets, personally having up to 12 layouts per sheet file, but in ACA the sheet creation process when using PN to create the sheets, follows that NCS recommendation. When attempting sheet, view, and xref management yourself, anything goes. When I use ACA, I find PN methods worthwhile.
AutoCAD Architecture - About Sheets -is worth reading.
It is possible to code/script the layout creation process to automatically create any layout setup automatically, including viewport creation. For those who just want a quick way of working, the "from template" option is preferred to the "new layout" option.
Architect, Registered NC, VA, SC, & GA.
