Custom Column Grid Bubble
kchesnokov
Observer Observer
kchesnokov
Observer
Observer
Hey Guys,
How do I create a custom column grid bubble which I can access from the custom column gridline editor?
R_Tweed
Insert the block definition “custom_colum_grid_bubble” right click and copy block definition.
Edit your new custom block and save.
Use the stylemanager to make a copy of the multi-view style  "custom_colum_grid_bubble" and give that a new name.
Edit your new style and add the new block under the view blocks tab. This will be the new "block" you made. Mine has (2).
Remove the original custom block and your set.. Now your new style will show up
