AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Curved Beam AutoCAD Architecture 2016
4 REPLIES 4
jessicaLZ6MA
859 Views, 4 Replies
I am trying to model some structure in AutoCAD Architecture 2016 and some of the elements are curved trusses and beams.  I drew the path I wanted it to follow, right clicked on Beam in the Tool Palettes, went to Apply Tool Properties to - Linework.  This created the curved beam, but currently the web follows the path and I need the flange to follow the path.  I tried to change the roll and that was not the answer.  Attached is a picture for reference--the white line is my path.
Any and all suggestions will be greatly appreciated.
Jess
4 REPLIES 4
David_W_Koch
in reply to: jessicaLZ6MA
If I understood your screen capture correctly, you have a curved beam similar to #1 in the picture below, but you want the orientation of the structure member to be like #2.2017-02-15_ArcBeams.png
I thought about creating a new Structural Member Shape Definition, with the defining linework rotated 90 degrees, but then decided that was too much work and not necessary.  To get the result at #2 above, I simply copied the Structural Member Style, gave the new style a meaningful name and, on the Design Rules tab, changed the Start Shape's Rotation property from 0.00 to 90.00.  Since the End Shape is set to be a duplicate of the Start Shape, the End Shape's Rotation Property automatically changed to 90.00 as well.  Using the rotated style gave the desired result.2017-02-15_RotatedStructuralMemberStyle.png
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
jessicaLZ6MA
in reply to: David_W_Koch
Brilliant!! Thank you so much!
jimmydee
I realize this is an old post, but is the option to curve a beam really in AutoCAD Architecture 2016?
I don't see an option to apply to linework.
Jim
David_W_Koch
in reply to: jimmydee
@jimmydee
Create a tool palette tool for your structural member style.  Right click on the tool and choose Apply Tool Properties to > Linework.
David Koch
Blog | LinkedIn
”Boost
