CREATE A NEW VIEW TAG
BCHRISTIANVMLQM
BCHRISTIANVMLQM
I AM WORKING IN ACA 2022. I HAVE CREATED A NEW VIEW TAG AND MY NEW ONE DOESNOT REQUIRE THE POLY LINE. DOES ANYONE KNOW HOW TO DISABLE THE POLYLINE WHEN I INSERT THE VIEW TAG?
THANK YOU, BYRON
David_W_Koch
@BCHRISTIANVMLQM
Creating a block with a polyline is part of the programming behind the _AecTitleMark command.  The width of the polyline can be set to 0, but it cannot be suppressed.  It can be erased, afterwards, but I assume you are looking to avoid the need for that.
Is your custom Title Mark made up of one or two block references?  It may be possible to find another command to add what you have, without a polyline.  Maybe even one without unwanted side effects.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
