Compare in AutoCAD Architecture 2019
john.vellek
Alumni Alumni
Message 1 of 1
john.vellek
With AutoCAD 2019, comes the drawing Compare feature. (Click here for more information on COMPARE in AutoCAD 2019) In vanilla AutoCAD, COMPARE allows a visual comparison between different versions of the same drawing. If those drawings have MEP or ACA objects you will get incorrect results.
If you are using the MEP (AutoCAD MEP) or Architecture (AutoCAD Architecture) toolsets, the COMPARE works differently.  Rather than reflect the changes between drawings, the comparison is between objects.  Please see this article for more information.
If you want to perform a drawing comparison similar to vanilla AutoCAD's function, please utilize DWGCOMPARE.
John Vellek
Replies (0)
