Cleanup walls by border
staler.pc
staler.pc
Hello! I have a file with walls which cleanups to each other if their border is intersected and baselines don't.
But I haven't any idea how it happens.
What the property should I change to use this function?
The file and screenshot is attached.
David_W_Koch
The horizontal Wall has been merged to the vertical Wall.  Remove the merge and there will be no apparent cleanup.2019-04-04_ACA2020_WallMerge.png
You need to turn on Justification Display in order to see the dashed arc that represents the Wall Merge.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
