I like using spaces for lots of things because they are very easy to edit on the fly.
Slabs are good if you need an edge style (cornice) but they are a pig to edit (IMHO) in comparison.
ME's a supposed to be THE flexible object and if you have anything other than a flat plane they might be a good option but for a flat plane you cannot beat the ease of a space object.
For ceilings I use different objects depending on the shape, using the strengths and weaknesses of each aecobject.
Slabs for areas requiring a cornice (edge style)
Spaces for random bulkheads. flexible as long as flat in plane.
Walls for a running bulkhead with brick lintel. (generally a set width. Sections show complex construction).
If you have a general ceiling with cornice, with a hole in the centre with raised section (if that is what tray means) then a slab with a hole cut does well. I have used a second slab with a special edge style for the downturn and if I did that a lot would make a custom edge style for it. That way it will section nicely.
Good time to post a question on spaces?
I use aecSpace objects to track the overall size of a building and each separate bit. (Since aecArea objects were killed).
But if you have a space already over the building, I couldn't create auto room space objects. It seems there are limitations to having mutiple space objects in the same space. I use space objects for any floor coverings, Paving etc.
Since spaces should cover overall areas + room sizes I don't understand what everyone else is doing here?
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
