can't remove indent via VBA
brian_adams
brian_adams
In notes of style I made construction description and  I need it with transfering of text of every construction layer to another line
But I also need it as single string with no indent
what  I do wrong?
 It works only  If I make formation  with (vbCrLf) but if i use "enter" for transfering of text to next line it ain't works at all3432.JPG111.JPG565656.JPG
dbroad
You can't just type the field name [NotesFromStyle] in. You must select it from the list (it must appear gray). This also affects copy/pasting code. This is an AutoCAD Architecture program bug in my opinion.
Architect, Registered NC, VA, SC, & GA.
brian_adams
Yes, I know it is bug, but it just sample I made quickly
issue is , when I made a list in Notes of Style with using enter to bring  next string down it ain't works with "split" or any other vba function, but i solve it making single string and do some VBA manipulation to depict it like list in manual property
dbroad
Post the drawing if you want more help. It's impossible to debug with pictures.
brian_adams
Thanks for you willing to help. I solved it, turning issue upside down
