Can't get a SELECTSIMILAR SEttings
hwangky
hwangky
Hi.
I recently changed my AUTOCAD version from AUTOCAD 2019 to ACA 2022.
I used SELECTSIMILAR command very much in AUTOCAD 2019.
I know this command works as AECSELECTSIMILAR in ACA2022.
My question is  when I type this command, I could see the SEttings -the sub menu in AUTOCAD. But in ACA2022, I can't find this menu on commandline-in nowhere. Is the command system changed?
pendean
Community Legend
Community Legend
commandline? SEttings has always been a pop-up in AutoCAD 2019-2022 for the core SELECTSIMILAR command.
Perhaps you ran a LISP or something else?
hwangky
Sorry. I made you confused.
As you said SEttings is pop-up dialogue.
When I want to change the selecting option, typed 'SE' after SELECTSIMILAR command in AUTOCAD 2019. Then the dialogue box is showed up. But that 'SE' is disappeared in ACA2022.
Is it because I use any lisps?
hwangky
