Can't change column rotation with enhanced custom grid in ACA 2019
Spaup20
Spaup20
When using a enhanced custom grid in 2019, I've found that when you try and insert a column from the structural member catalog, you cannot rotate the column.  I've changed the rotation to specify on screen, and it still won't let me change it.  It looks correct when you change the roll but when you hover over the grid it changes it back to what it was.  Is this a glitch in the new version?
@Spaup20 for clarity VStudley edited the original subject: ACA 2019 - Enhanced custom grid
Victoria.Studley
Hi @Spaup20,
I'm having a bit of trouble understanding what you mean here. Could you record and post a quick Screencast video showing us exactly what's happening?
Could you attach a sample DWG file where the issue is happening?
This will help us understand the workflow you're using, and should ultimately get you a quicker solution.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @Spaup20,
Do you still need help with this issue? Will you be able to provide the additional information I requested in my previous post?
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Spaup20
I will, I just haven't had time, we got kind of busy in a hurry.
Spaup20
Here is a screencast of what I was trying to explain in my previous post.  I hope this helps.
dbroad
I think this defect has been around for a while.  Same thing happens on ACA 2017.  I usually just place or autopopulate the grid and then select and change the roll in the properties palette.  I agree that this should work properly though.  The Screencast effectively demonstrates the bug.
Architect, Registered NC, VA, SC, & GA.
