Can not see intersection point on surface after imprint command
alexander.naljot
alexander.naljot
Dear ACA community,
I have a problem with _imprint command in Autocad Achitecture. After applying the imprint command the intersection point is not on surface. I have tested the same procedure on the other machine and it seems to work there.
I think it depends on the settings. Has anyone had the same problem?
Thank you for the response,
Alex
alexander.naljot
Hello dear Autodesk Community,
I figured it out and it's very simple.
1. Surface associativity should be turned off. Afterwards it should work.
