Can I make a personal template for view file in AutoCAD Architecture
kostimea
kostimea
Is there a way to make a personal template for the settings of a view file in a project?
I would like to change the room tags, and the display setting of window and door elements. I would like it if all new view files would use these settings, not the standard ones.
thank you in advance
@kostimea for clarity VStudley edited the original subject: template for view file
You can create your own template file for your view under project navigator.
You have to create your .dwt file   which has your custom style and save in your project navigator folder under template under your project navigator folder.
And then go to project navigator property by clicking button(find attached "picture 1")
Under   template, linked view template file with your custom file(.dwt)(find attached "picture 2").
Chirag
