- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I created a customized tool palette. Some of the blocks work fine, others give me the following message:
Command: Block 42 ROUND TABLE references itself
Command: Block STD DOUBLE BOOTH references itself
Command: Block BANQUETTE references itself
Command: Block 24 ROUND TABLE references itself
I've check the properties to make sure the path is correct and I've purged each block. I've searched other forums and I found some explain it maybe that the block is named the same as the drawing. I'm not sure if this is the problem. If so, I haven't read in any of the forums how to solve this issue.
It's left up to us to be our own CAD Manager and I'm not skilled enough to figure it out. Any help would be much appreciated. I've attached one of the trouble makers.
