Block Names to IFC file
Ryan
Message 1 of 1
Ryan
Hi all,
Im trying to export a 3d dwg file propagated with  blocks to IFC. I've followed the information in To Map IFC Object Attributes to AutoCAD Architecture Property Set, and can link the block name to an IFC property. But when I try to import the IFC into revit, the information is lost. Am i missing a step?
Also, Revit doesn't seem to be mapping the IFC properly. The blocks should be set to IFC-Beam which Revit should treat as structural framing.
Replies (0)
