AutoCAD Architecture - wall cleanup on 2d section
Reaya
Reaya
Hello ,
I have two walls intersecting with T-cleanup .
I  have placed horizontal section and generated a 2d section .
Walls in model cleanup ok .
2d section walls not cleaning correctly and hatch pattern not joining .
Attached are a dwg file and a screenshot .
Can you help me ?
Thank you ,
Reaya Hevron .
[The subject line of this post has been edited for better findability by @handjonathan Original: wall cleanup on 2d section ]
ArnoldHoogenboom
Merge common materials tick that box.
they're section objects. the objects dont merge naturally in horizontal section.
The view in plan view is the plan hatch. The view in the 2D section is the section hatch.
Which means you need to set them all to "global"
Is that what you meant?
Bouwkundig tekenaar, gevestigd te Roelofarendsveen, Nederland
Reaya
Thank you , it works ok .
Reaya Hevron
