Announcements
AutoCAD Architecture - Split Wall Appearance
austinkb
austinkb
I am attempting to create a building where the first 4' of the wall (from the ground up) is one material and then the remainder is a different material. I realize I could put two walls on top of each other and assign materials accordingly but that would take too long for what I am trying to achieve due to size of projects.
I tried making a 4' thick slab and modifying the edge appearance to be what I want the bottom exterior wall to be; but couldn't seem to figure that out. (Again, the top of the slab and the sides are different materials) That would be the easiest solution if possible.
Any other ideas please let me know. Attached image.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (7)
pendean
Community Legend
Community Legend
"too long" is the correct method. 4' slab? Curious how you got there as a quicker workaround 😉
What is your goal here, a quick "show someone a concept" or something else entirely?
austinkb
No, I am asking if I can edit the sides of a slab to a different material to reach my end goal. I tried messing with the rendering display properties to no avail.
 That would be a super simple solution since I need to have a slab element anyway. The slab obviously isn't 4' thick but the slab is at an elevation of 4'. Below that is a concrete foundation perimeter, and the walls are corrugated sheet metal.
I am doing this to many multiple warehouses. Having double walls stacked on each other is time consuming and messy. Just asking if there is a workaround I am unaware of.
faugustom
For the wall, you could create new styles editing the top and bottom properties of different components:
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
For the slab, editing the edges:
austinkb
Super close. I added a vertical offset of 4' from the bottom, combined with a slight edge offset between the two materials to expose the base material. However, that base material still comes through in openings like windows, doors, etc.
Is it possible to do a vertical offset equation like (Base Height - 4') from the top of the wall? Similar to the edge offset equations? That way it only applies to the bottom portion...?
faugustom
R_Tweed
Is this a wainscot or raised curb?  You can go down as well with other components.  Here is an example file for what I use for metal buildings with the addition of some footings.
austinkb
This is exactly what I needed. It seems so simple when you look at how you did it in the properties. The piece I was missing was utilizing the "from baseline" offsets rather than just the top/bottom of wall. THANK YOU!!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
