AutoCAD Architecture - Export layout w/ viewport settings
nfranklin9Q4AQ
nfranklin9Q4AQ
I'm trying to figure out a way to create a layout template while retaining the viewport settings (VP color, VP linetype, ect...).
Is this possible? Is there a different approach?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
pendean
Community Legend
Community Legend
In a quick test in one of my on files EXPORTLAYOUT command seems to work just fine like you want it: did you try it? What failed? Can you save actual CAD files?
handjonathan
Hi @nfranklin9Q4AQ
Thanks a lot for posting your question to the forums!   Has the solution suggested by @pendean helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
