Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Autocad architecture cut plane Problem
Beka_Tchigladze
Beka_Tchigladze
Hello I have such kind problem so I have drawing in autocad architecture 2020 if my windows place on 0.0 elevation in the plan it shows well, I mean that masking working well and there is not shown wall hatch under the window, but immediate when I try to move up windows on their real elevations wall hatch are shown under windows.
there are screen shots and .dwg also
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
dbroad
That doesn't seem unexpected.  Are you sure those cut plane and display above settings are reasonable for millimeter units?  That would put the cut plane only an 1-1/2" above the floor.  I would think 1300 would be a better cut plane height and 2625+- would be a better display above setting. That said, you can override the cut plane for a window and the wall that hosts the window. You can also change the display settings.  I don't think you can remove the wall hatch below the window though if its above the cut plane.
https://knowledge.autodesk.com/support/autocad-architecture/learn-explore/caas/CloudHelp/cloudhelp/2...
Architect, Registered NC, VA, SC, & GA.
Beka_Tchigladze
I have solve this problem like so.
I have changed wall cut plane on that level to cut windows and also manually add cut plane to cut doors to get rid of additional contour lines on the door frame.
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
ntellery
My cut plane is 1900 which tends to catch most windows including small toilet windows high on wall.
You can edit a cut plane for any one wall but if you have more than one window that are high and low it can be tricky.
As said, you can tell a window (by style or object) to ignore the cut plane of the wall and show anyway but the wall still doesn't cut.  I generally use a masking object to hide the wall and it needs to sit at the same elevation as the wall (0,0?).  Draw a rectangle around the window, select it and turn it into a masking object (right click option?) and select the wall to add to hide.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
