AutoCAD Architecture - Change wall baseline location
Reaya
Reaya
Hello ,
I have a wall style with multiple components .
I placed a wall in my drawing .
I set Justification to Baseline .
I now want to change the Baseline location in the wall .
Attached are two screenshots .
Can you help me ?
Thank you ,
Reaya Hevron .
[ The subject line of this post has been edited for better findability by @handjonathan Original: wall baseline ]
dbroad
A wall style's baseline is at the offset of 0.  If you want to adjust the  baseline, use the wall style editor and at the bottom of the dialog, enter the distance you want to move the baseline into the offset increment. Then for each wall component, select the component and use the left arrow or right arrow in the offset increment area to move the component the desired direction.  Adjusting the wall style in this fashion may also require editing the wall cleanup styles for that wall style (endcap and opening).  As you might know, there are alternative justifications that could be used instead of moving the baseline such as left, right, or center.
Architect, Registered NC, VA, SC, & GA.
