Hello everyone!
I have upgraded to the 2323 version of Autocad Architecture and have found that I can no longer use the "FILLET" command on walls. I have found that you have to use the "AECFILLET" command to fillet walls. Okay, I got that, but I have to type in A-E-C-F-I-L-L-E-T in the command line every time I want to execute the command!
Typing in this command each time is time-consuming and cumbersome for me each time I want to fillet the corners of walls. I like pressing key commands, not typing commands!
How can I make this a shortcut key such as "F -key = Fillet" in the PGP files?
