Arcs changed into sharp angles
I'm using ACA 2015, and this is definitely an easy fix, but I'd like to prevent this from happening again in the future. I was working on a project and drew an elevation of a curved bracket using the Arc command where needed. I saved the file and closed the program, and went to lunch. Upon my return, I opened the project and now all those curved arcs are sharp angles.
Any clue as to what happened here??
dbroad
Post the drawing.  Did the geometry actually change or the display of the geometry?  (regenauto, viewres settings?)
Architect, Registered NC, VA, SC, & GA.
So, I just did a regen and the curves went back to normal. Also, when I just exported the drawng as a PDF to upload it here, the curves showed up as normal in the PDF. I'm guessing it's just a visual glitch in the display of the geometry?
dbroad
Set your viewres higher (10000 to 20000)
