Annotative Objects doesn't work in AutoCAD Architecture
Baqari
Baqari
Hi everyone
 I'm using many annotative objects in my drawings such as texts, blocks wit attributes and etc. I don't know why but these objects does not work properly. When I change my scale sometimes they adjust, but sometimes they don't. I have pictures below as an example with same object with different scales, but text remains the same size. It's randomly doing this in some files, not in all files. But the thing is, that in every file some objects do have the problem and does not work as they should. I don't know may be something is damaged in these objects, but I couldn't find the reason. They were working just good when I made them, but now they don't anymore.
 In the pictures below you can see some of my annotative blocks with attributes with different scales. I also attached screenshot from block editor, to see what's inside the block. It's the same text, with same text style and everything. Just the shapes are different.
 If you can help me find the problem would be much appreciated.
Regards
pendean
Community Legend
Community Legend
Variables to check to ensure they are at least at the recommended setting noted in HELP:
ANNORESET (Command)
ANNOUPDATE (Command)
OBJECTSCALE (Command)
ANNOALLVISIBLE (System Variable)
ANNOAUTOSCALE (System Variable)
SELECTIONANNODISPLAY (System Variable)
DIMANNO (System Variable)
Baqari
Thank you very much. OBJECTSCALE (Command) worked for me. Seems like i just needed to add scales from the list. That's why it was working only for some of them. I added all scales I need and for now it works just normally. Hope it stays like this. Thanks again.
