Annotation Problems ( Square straight leader)
Good afternoon All,
Recently started training in AutoCad and everything has been going smooth until now.
When i select Square straight leader, the second line going to the box is extremely long for no reason. When i try to resize it before setting it, it wont adjust to where i want it. I have googled and watched videos and cant seem to find my answer. Thank you in advance.
pendean
Community Legend
Community Legend
LANDING size (arrow pointing to it) is a set dimension in your MLEADERSTYLE that you need to change there. You can also change it manually this one time in PROPERTIES.
As for arrow size: it could be your arrow size setting also in MLEADERSTYLE command.
THANK YOU !!!!!!!!
