The Problem
I started experiencing this issue yesterday where, while using AutoCAD, the alt shortcuts menu keeps on appearing whenever I type, interrupting my workflow. This occurs if I type in the command console, if I type in dimensions, and any time I touch my keyboard when the application is focused. I am not hitting the alt key when this occurs. The Alt key still works as normally and makes the alt shortcuts menu disappear and reappear.
Similarly, clicking also triggers this though the behavior is less predicable than with my keyboard. But whenever I click on any fill-able text boxes, or when I try to click on the main drop down button with the AutoCAD logo, the alt shortcuts menu appears too.
This makes using the program unusable since I'm unable to type in exact dimensions. Even if I make the alt shortcuts menu disappear, it somehow interrupts my typing so I can't write more than one character in the dimensions.
This issue only occurs in AutoCAD Architecture 2025. Other applications that use alt shortcuts, including other versions of AutoCAD, work as expected. The issue went away for a few minutes when I restarted my laptop, but came back unprompted.
Specs
Program: AutoCAD Architecture 2025
OS: Windows 11
Device: ROG Zephyrus G15
Screenshots and Video
(In the video, whenever the alt shortcuts menu flashes, I'm trying to type or click)
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
