AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AEC Objects Explode - Multiple copies of Xrefs are binded
4 REPLIES 4
biju_KK
855 Views, 4 Replies
I am trying to e-transmit a project done in ACA2010 but I am getting all the binded files have multiple copies of xrefs. I.e. if I have xrefed General Arrangement plan to a detailed layout and I have 3 no's layouts / vports then after aec explode there will be 3 no's General Arrangement plan blocks one over the other.
Have anybody come across this issue ? Is there any solutions?
4 REPLIES 4
David_W_Koch
in reply to: biju_KK
In order to allow each viewport to show unique graphics for AEC objects (each one could have a different Display Configuration/view direction chosen), when you Export to AutoCAD (AEC Object Explode), a separate Model Space block is created for each viewport.  This remains true even if multiple viewports have the same Display Configuration/view direction and the same layer settings.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
biju_KK
in reply to: David_W_Koch
Then in that case it should happen when we do  exporting to Autocad from the AutoCAD pulldown menu -> Export -> AutoCAD, but this way it works fine. In my case this only when i use e-transmit to bind & AECexlode.
Hugh_Compton
Try exporting to AutoCAD when you are in modelspace.  This way only one modelspace block is produced and you will eliminate the unwanted extra blocks.
3D AutoCAD Pipework - http://www.HerculeDesign.com/
biju_KK
in reply to: Hugh_Compton
Thanks Hugh,
Yes it works, but is there any way to change all the drawings to model space prior to exporting then save it back to paper space ?
