ACA 2016 On Windows 10 DirectX error
tevansERD
tevansERD
I had a hardrive fail so i replaced it and installed Win 7 then upgraded to Win 10. When trying to install ACA 2016 I get an error to install DirectX prior to installing AutoCAD. Is there a fix for this or do i need to roll back to Win 7, Install ACA 2016 then upgrade to Win 10?
jeffrey.sin
Hi @tevansERD,
The 2016 version of most AutoCAD-based verticals should be installable and perform as expected on Windows 10. You may check out these links to find additional information on it. You may also try out the solution for the .NET 4.5  error as this may also be applicable to the issue you are seeing.
Windows 10 and .NET 4.6 support for Autodesk products
Error: ".NET 4.5 is not installed" when attempting to install Autodesk 2016 products on Windows 10
Kindly let us know how it goes.
Thank you,
Jeffrey Sin
Autodesk Customer Support
