AC 2022 Content Browser crashing
Message 1 of 8
I have a problem with adding some dynamic blocks into palettes in Content Browser. With "normal" blocks, AEC objects, Schedule Tables etc. etc. everything works fine, but when I'm adding some dynamic block I can't enter into the palette because CB is shutting down without warning and there is no error note or anyting. Maybe anyone besides me had this problem and solved it?
Replies (7)
Message 2 of 8
richld
I'm having the same issue here any time you try to add a dynamic block into your content browser it will crash. Also if you brought over your catalog from older an AutoCAD and you click on the palette that you know contains a dynamic block  the browser will crash. you are still able to add in the palettes through a few workarounds. But creating new palettes and deploying them is next to impossible right now.
Message 3 of 8
mknx
Same issue here... this is no problem when using AutoCAD 2021.
For now i'm using 2021 when i need to deploy new/updated palettes. There are a few more issues with blocks and 2022 that might make me switch back to 2021.
Message 4 of 8
Dimitry.Okken
Observer
Observer
same here...
i added the companies custom catalog to the contentbrowser (clean 2022 install,). if i open the custom library, its shows all chapters. but as soon as i want to open a chapter which contains all of our dynamic blocks the contentbrowser immedialty closes....no error mss nothing. just poef and it's gone.
no problems in 2021 btw....and its the same catalog we have been using for years (so no problems with older versions either)
Message 5 of 8
pendean
Community Legend
Community Legend
Message 6 of 8
Dimitry.Okken
Observer
Observer
already did 😉
Message 7 of 8
Yup, me to, in parallel with posting here in august 😉 So far no effect despite two updates. Well...
We managed workaround - when we made static blocks from dynamic blocks we could put them in palettes. Annoying but works so far.
Message 8 of 8
By "static blocks from dynamic blocks" I mean dynamic block into static block (one level Inception;). Put them in palettes with explode option.
