abnormal display in AutoCad 2016
I have a problem with the display of AutoCad 2016. I have the education version. The text is never at the right size. The tool bar is too small and the options too big for the emplacement.
Attached the screenshot.
What's the problem? the software or Windows 10? Is it possible to have a former Autocad's license? maybe Windows 10 doesn't support Autocad 2016.
Thanks for your help, I really need to use AutoCad for my job.
M.
leothebuilder
You're a naughty boy using educational version for your work
I'm a student, third year.
leothebuilder
I was just kidding.......
Check your the  display resolution of your system.
I believe with the latest updates/patched for 2016 that it is compatible with Windows 10....please check this yourself
David_W_Koch
This Autodesk Knowledge Network article addresses the issue that @leothebuilder mentioned.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
