Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
A software Problem causing AutoCAD to close unexpectedly.
1 REPLY 1
605 Views, 1 Reply
I have been having this problem since I installed. It happened when I am either opening or closing a drawing.
IT has "repaired" AutoCAD had hoped that would fix the problem. But I started up today and was drawing away when I closed some drawing it happened again. I have sent me report multiple times and have no heard anything back. I have looked on the Internet for suggestions to no help.
I am not sure what I should do. Attached it the Error Report I receive when AutoCAD Closes.
This has happened at least 5 times in the past 3 days (?) It has also just stop responding all together and I had to force shutdown.
Any tips suggestions ect would be appreciated.
1 REPLY 1
I have had this happen to me in the past. What was causing my problem was that I was trying to use a very tight curved profile at the top of a wall to make a rounded corner on the parapet. AutoCad Architecture did not like this at all an so it crashed. I had to re-think how to show the corner in plan view as opposed to model view and came up with a solution. I don't know what you are drawing, but if you are doing something similar to what I did then you should try something else. I actually had to show plain linework to represent the rounded corner in plan view and mask out the square corner (also in plan view). In elevation, I had to do the same thing. Showed curved linework for the rounded parapet and masked out the square part using a material boundary. Hope this helps, James
