2019 block editor/edit block in place
Spaup20
Spaup20
So I guess Autodesk has really given up on fixing things in Autocad Architecture.  The block editor in 2019 does not work when you choose edit block.  This was the same thing I brought up in 2018 and still isn't fixed.  It had something to do with migrating settings from a previous version.  Ummm, you've had plenty of time to fix the known issues and yet haven't.  Not to mention there has been no comment from Autodesk for a previous issue I had with columns and custom column grids.
pendean
Community Legend
Community Legend
No one reading your messages is "autodesk", just us end users like yourself.
What is broken exactly and how do we repeat your exact issue? Show us, post a DWG and want us through howto repeat it with your cotent.
Victoria.Studley
Hi @Spaup20,
If you're referring to the same block editor issue you posted about last year, it was fixed in AutoCAD Architecture and AutoCAD MEP 2018.0.1 Update (the first update released for those vertical products last year). You posted about the fix in this thread for another user.
If the same issue is happening in 2019, then it is likely that the fix for 2018 is not installed on the machine, which could cause the issue to occur in 2018 and then migrate forward to 2019.
Could you verify that:
  • This is the same issue you were experiencing last year that was fixed in the update we provided.
  • The 2018.0.1 update is installed for ACA 2018. (Not AutoCAD 2018.0.1, but AutoCAD Architecture 2018.0.1, as they are different updates.)
If the 2018 fix was not installed prior to migrating, you'll need to install it and then migrate your settings to 2018 again, and then to 2019.
If one or more of these posts helped answer your question, please click Accept Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
